![]() | Home > Maintenance & Mods (L322) > Roof Racks |
StuManchu Member Since: 31 Dec 2023 Location: Leicester Posts: 28 ![]() ![]() ![]() |
Yeah, you'll need to transfer the whole lot, it's a 10 minute job, they'll be 6 (3 each side) bolts in your roof 'runners' undo them, take runners off, if you can do it with someone else you can leave the bars in situ and move it all in one go, the little tabs on the 11 plate will just need a little screw driver to pry open, these will need to be removed, there is a knack to it, as a lot tend to snap, once they're off, just sit your runners over the same holes as before on the other car and put your 6 bolts in. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 763 ![]() ![]() ![]() |
thx Stu - even I can tackle that I reckon |
