Home > Maintenance & Mods (L322) > Deployable side steps
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Has anyone retrofitted the deployablea side steps and is it a big job? Wondering if it's just the steps and brackets that need to be fitted or is there additional wiring?
Post #696663 22nd Jul 2024 5:32pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
quite a few posts on it, seems to be relatively straight forward but time consuming
https://www.fullfatrr.com/forum/topic63457.html 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #696668 22nd Jul 2024 6:36pm
bob-lad
And then once you've done it you'll wish you hadn't bothered.
They either bash you on the shin or get stuck.
Spent ages looking for a fatty with them, wish I hadn't bothered now.
I'm probably going to swap mine for ones that don't move, get stuck in up or down or just annoyingly half way.
Harumpfh.
Post #696821 24th Jul 2024 2:51pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I love mine; they’re plush and add a sense of theatre !
Mine were factory fitted options. No real problems with them in the two years since I’ve had the car. They did stick a little when the weather was really cold this winter but they haven’t been serviced during my ownership.
Planning to do a light overhaul later in the summer as prep for the coming winter.
Wouldn’t be without them. TDV8 4.4 2012
Post #696828 24th Jul 2024 4:02pm
dhallworth
I've fitted 2 sets now.
The fitting of the actual steps isn't difficult although the drivers side step is fiddly as the air receiver for the suspension is right in the way of getting a ratchet onto them so it's 1/4 a turn at a time with a spanner.
Fitting the wiring isn't difficult but it does take time. You need to remove the chrome tread plates and the plastic trim in front of them on both sides. You then remove the end panels off the dashboard on both sides, remove the wooden trim on both sides, remove the A pillar covers on both sides and the centre console above your head to mount the sunroof switch.
Fitting the wiring isn't difficult either but just takes a bit of time to finesse it to where it needs to be. It's easily done in an afternoon.
Do you have a set of steps? I have a complete set with wiring loom, sunroof switch and ECU along with all the fixings that I keep meaning to sell. The wiring loom is for a 2007 - 2009 car but the looms aren't that expensive and are still available from Land Rover. It's just the steps, brackets and motors that aren't.
Post #696834 24th Jul 2024 7:29pm
