![]() | Home > Technical (L322) > New owner - several little niggles - camera, oil leak etc. |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 57 ![]() ![]() ![]() |
not sure about the loom but the camera is still available form Landrover at around £450 or so each....... finding them second hand is like finding hens teeth.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1445 ![]() ![]() |
Each to their own, but the 360 cameras are such poor quality, even on the L405 that they're practically useless and I never use them.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 ![]() ![]() ![]() |
Do a search for oil cooler leaks on this forum and you will find plenty of info on this universal problem. Pity as most cars now should have had this fixed but maybe it's on it's 2nd failure....
James23 Member Since: 10 Jul 2024 Location: East Midlands Posts: 4 ![]() ![]() |
Oof £450! I hope it's just disconnected then! Thanks for the tip about the reverse lights.
They aren't great quality but if something is fitted I'd like it to work. Ah okay, I have heard about the oil coolers on these, I'll do a search on where to look to see if it is that. Will check out the oil feed hoses too thank you. Oh okay thank you I will get it swapped then. Would I be better off registering the change in a week or two once I've sorted some diagnostics out or just leave it? Jaygee - thanks. I guess it will be the oil cooler then I will have a look today. The wiring is not in the boot it's under the car at the sill where the air suspension tank is approximately where the drivers door is. Thanks for the replies so far guys |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 174 ![]() ![]() ![]() |
Wiring might be a for the TPMS antenna ? |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 107 ![]() ![]() ![]() |
They look interesting. How do they look on the car? Can you post a photo? Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
looks a lot smarter than the 3 LED ones I think/.
Totally agree, worth a try.
I've taken the oil cooler off - it is a Mann+Hummel from 2016. From looking at the MOT history it's done 75-80k miles but looks like it's been leaking for a while. Bought a Nissens one to replace it.
