Home > Maintenance & Mods (L405) > Rear seat problems
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Rear seat problems
Hi Guys, I have had a problem with the large rear seat not working.
I have extended warranty and have asked JLR to look at it when it was in 6 weeks ago when it was in for a flush of oil on the transfer box.
I was informed then that it had loosed communication but needed to book it in for investigation,
So last Friday the car went in for two days and when I picked it up I was told that after inspection the 30amp fuse had blown on 58 rear fuse bank.
This I questioned as if a fuse blows then it would point to a short or an overload?
ie: the seat is jamming or the motor is failing.
I was told its working now, you owe us £12 for the fuse as its not covered under warranty.
I went out to collect the car and checked the function of the seat and it was working and went home.
So the car sat for Tuesday, this morning Wednesday I open the car up, pressed the button and click which sounded like a fuse pop the seat did not work.
I checked the fuse and it had blown again. Censored
On the phone again three times to get the service agent to answer me the car is now booked in for the 2nd of September. I have been told. that they will have to pull the carpets out to check the wiring loom.
Has any one else had a problem with the rear seat blowing fuse's. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #696398 17th Jul 2024 3:59pm
