Home > My Range Rover > 255/50/20 tyres on my Evoque
EllongoSB46
Can anyone tell me if I will have a problem using 255/50/20 tyres on range sport wheels on my 2016 Evoque, I know the stud spacing is different and I can source converter flanges to cure the spacing problem.
Post #695998 11th Jul 2024 3:51pm
If you have an Evoque then you're on the wrong forum...
Scroll down to the bottom on the main index page and you'll see the link.. ... - .- -.
Post #696000 11th Jul 2024 3:59pm
MarianaWestminster
You could use a tyre size calculator (If you Google it there will be a few different websites)
Enter the current size of tyre fitted to your Evoque and then enter the tyre size from the Sport.
You'll be presented with a comparison chart and a visual diagram comparing the two.
If the overall rolling radius and width of the 2 are pretty similar (within millimeters of each other) then you'll at least know if they physically fit.
The differing offsets and of course the bolt pattern may/will cause issues.
Also be aware the smaller/larger rolling radius compared to original will cause your speedometer to over or under read.
Post #696049 12th Jul 2024 9:32am
