Home > Technical (L322) > What line or pipe is this? 2010MY 3.6 TDV8
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Afternoon all,
I once again come to this knowledge base for some assistance.
I was doing the first oil change in my ownership of the car (bought in Feb) as it was last serviced in Nov 2023 and come across this broken pipe.
The rest of the pipe follows the below route (in yellow)
It looks as if whoever’s done a filter change in the past has clamped down on this pipe in the housing causing it to snap Rolling Eyes
Now I don’t have any codes but I also don’t know where to start looking to check live values of something to see if something is missing.
Any ideas what this pipe is and does? I can then go about seeing how to replace/fix it.
Thanks all in advance!
R 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #695997 11th Jul 2024 4:43pm
rryan
Quick update, turns out I had some old tubing and mace managed to seal it back up and reconnect it. Much easier than expected… result.
Though I’m still curious what it was/does and what it’d have affected. Looks like a vacuum line and I’ve seen about it controlling something to do with the manifold? Interested to hear your thoughts. 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #696002 11th Jul 2024 5:10pm
rryan
To continue, and close, this thread of me having a conversation with myself...
Having repaired the pipe/line with a bit of tubing and tape, it's clear that it was indeed a vacuum line. A notable improvement seen is that in the brake pedal. I used to have a fair bit of travel here, thought it needed bleeding but the fluid was almost new.
Turns out it must be vacuum assisted somewhere as the pedal's never felt better! Happy days. 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #696025 11th Jul 2024 9:25pm
kevinp
Glad you got it sorted. I'm trying to source something similar with my brakes.
Post #696028 11th Jul 2024 10:59pm
MarianaWestminster
I believe the vaccum line in question operates the actuator which operates the 'manifold tuning valves' within the intake.
Your brakes are servo assisted using the engines vaccum so in fixing the pipe you have restored optimal vaccum in the system hence the improved brake pedal feel Thumbs Up
Post #696031 11th Jul 2024 11:14pm
rryan
You may well have a vacuum pipe loose somewhere then, fingers crossed it’s an easy one like mine. My symptoms were a fair bit of travel in the brake pedal but had normal braking performance, if that makes sense. A few presses after repairing the pipe gave it the consistent, firm feel I was expecting Thumbs Up 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #696167 14th Jul 2024 12:55pm
rryan
Very useful to know, thanks! I’m made up it was such a simple fix, quite rare these days! 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #696168 14th Jul 2024 12:56pm
pigeon_voyageur
France
Hi guy's,
I also have all vacuum lines either broken or about to break.
Trying to find the routing for these lines... Not so easy.
If it is only going to the swirl flaps in the intake manifold, the car might as well drive without it !
Post #701885 10th Oct 2024 7:28am
