Home > For Sale & Wanted > [For Sale] FULL SET SUPERCHARGED GRILLS + BONNET GRILLE L322
Scouse Exile
Hi, after a decision to put my 2007 Vogue back to what I assume would have been original spec I now find I have a spare set of grilles that would have been fitted to a Supercharged vehicle. Whether it could have been optioned at the time I'm not sure but either way I've taken then off.
They are presently in primer (the grille will be today) and the intention is to paint them in Land Rover LBO Brunel Grey finished with a matt lacquer but I guess if you are quick enough then there is always the option for me to finish them in a finish of your choice whilst I've got them ready to go. Maybe you prefer Satin Black??
I've attached a picture of what it will look like when painted for reference as I had to spray up the replacement set I fitted to the car. The grille will come with 2 x washer and all the fixings so it can be directly replaced without breaking anything.
Ideally for the full set I'd like £125 plus postage or happy within reason to meet halfway somewhere for collection so as to remove the possibility of damage in transit - so long as you don't live in Inverness then it should be Ok as I'll just tell her indoors that we are on a day out.
Hopefully they will be of use to someone, they will be like new almost by the time they are done.
This is the intended colour;
Post #695842 9th Jul 2024 2:58pm
Scouse Exile
These are now painted in Brunel Grey with a set of washer jets fitted to the bonnet grille. One of the side grilles needed a small plastic repair on the bottom tab that fits behind the lower plastic trim on the wing, it’s totally out of sight when fitted.
Post #696170 14th Jul 2024 1:27pm
Driyage
Ah I would have taken these unpainted as I wanted them in black!!
Post #696332 16th Jul 2024 8:51pm
Scouse Exile
Hi,
It’s not a drama to change them. I have some satin black if that’s the look you wanted or I can repaint whatever.
Let me know and maybe we can work it out so it’s what you are after. Either way they are no good hanging round my neck!
Jon
Post #696345 16th Jul 2024 11:11pm
Driyage
Hi Jon,
Just to double check, these would fit a 2012 facelifted 5L SC ?
I’d ideally have them in gloss black (to go with the theme I’m trying to put together)
Thanks
Don
Post #696359 17th Jul 2024 9:00am
Scouse Exile
Hello Don,
That I can’t be certain of in terms of fitment. I would guess they might but not sure.
Hopefully someone with more solid knowledge will confirm.
Jon
Post #696379 17th Jul 2024 1:33pm
the front grill wont but the rest will as long as its a 2012 L322.. ... - .- -.
Post #696382 17th Jul 2024 1:47pm
Driyage
Hi, thanks for the confirmation!
Apologies for the delay in response as I was away on holiday.
I can take the rest apart from the front Grille if you still like to sell them, ideally in gloss black !
Thanks
Don
Post #697118 30th Jul 2024 8:55am
Driyage
Thank you!
Post #697119 30th Jul 2024 8:56am
Scouse Exile
Thanks
Don
Hi Don,
I think I’ll try to sell them as is for now. It would take me about £30 in consumables to change to gloss black and I really want to sell them without having to repaint as got a lengthening list of other projects on the go currently.
Appreciate your interest, if they don’t sell maybe I’ll come back to you if that’s ok and you’re not in a rush.
Jon
Post #697123 30th Jul 2024 9:19am
Driyage
Hi Jon,
Thanks for getting back, I was of course going to reimburse you for the costs of spraying them black! However if you are busy I can understand. I’m in no rush for these as I have to get the tailgate rust sorted first…
Cheers
Don
Post #697126 30th Jul 2024 10:37am
Scouse Exile
Ok let me see what’s possible. If I’m only left with the grille then it’s a start!
J
Post #697127 30th Jul 2024 10:53am
