Home > Technical (L322) > Unidentified sound
SimonL322
Canada 2012 Range Rover Supercharged 5.0 SC V8 Orkney Grey
Unidentified sound
I've had my L322 for three months now. This past weekend I went camping, and drove 225km (140 miles) each way. I was doing about 120kph (75mph) for a large chunk of the trip. I had luggage up on the roof, and a hitch mounted bicycle rack.
On the way there I heard a random sound (maybe a buzzing sound or something actuating?)... It only lasted 1-2 seconds, so I was not able to pinpoint where it came from. It happened twice on the way there, and once on the way back.. it happened mid way through each drive too.
Any ideas what it may have been?
Thanks
Post #694257 11th Jun 2024 3:25pm
JayGee
If it's from the boot ( trunk) area then it could be the suspension compressor topping up the air resovoir. 2012 TDV8 Vogue (L322)
Post #694259 11th Jun 2024 3:35pm
SimonL322
Does that typically only take a second or so? I will try to pay more attention if it happens again.
It'd just be good to understand what the sound is, even if it's normal operation of the vehicle.
Post #694260 11th Jun 2024 4:56pm
Shaun_
It could just be the air conditioning system flaps moving about. Every so often mine do this audibly - I guess when the amount of movement is significant. Most of the time I hear nothing. I find it's especially noticeable when it happens if it's the ones controlling airflow to the rear seats (i.e. under the central cubby). 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #694415 14th Jun 2024 9:08am
JayGee
when stationary raise and lower the suspension to off road height twice and you should hear the compressor running as it refils the resovoir so you will know what it sounds like. 2012 TDV8 Vogue (L322)
Post #694423 14th Jun 2024 11:31am
