![]() | Home > Technical (L405) > 65 Plate L405 4.4 Oil Light Issue |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 177 ![]() ![]() ![]() |
I think I would be looking for the oil pressure switch. It's probably not as simple as that now but something must sense the pressure and switch the light off or on as required. A temporary gauge connected to the tapping would remove all doubt. It's been like that for 100 years but probably something ridiculously complicated now.
jimmy91 Member Since: 08 Jun 2024 Location: Essex Posts: 3 ![]() ![]() ![]() |
Thanks I will give this a go and see what I can find and report back my findings. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
A simple pressure switch is still used.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
Have you changed the oil filter recently? 2018 SE SDV8 4.4 Byron Blue |
Oh yes, must check that plug with every filter change. |
Mine does this when parked on a slope facing up. Never on the flat or facing down. Never got to the bottom of it but suspect something to do with how the oil pickup in the sump is situated. It’s definitely oil starvation as the engine noise changes when the light goes out. I always try to park facing down. 2012 TDV8 Vogue (L322) |
Thanks for the replies guys, I have now changed the pressure switch and it seems ok now.
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 48 ![]() ![]() ![]() |
I had the same oil light issue till I changed the broken leaf spring which sits under the oil filter since I replaced that no oil pressure light flashing on first start up 2012 Westminster 4.4 tdv8 |
