Home > Technical (L322) > 5.0 SC occasional repetitive clunking low speed acceleration
beeza
England 2010 Range Rover Supercharged 5.0 SC V8 Java Black
This is an intermittent fault on my 2010 5.0 SC. 70,000 miles. Sometimes when pulling away gently in traffic I hear a repetitive clunking from somewhere underneath at the rear end. Once I accelerate beyond 30mph it goes away.
If I let off the gas it also goes away. I'm thinking the culprits could be: transfer case, centre propshaft bearing, rear diff or rear driveshafts.
I can't see the propshaft bearing without removing the exhaust the heatshields. The driveshafts don't appear to have any play and there isn't any backlash in the drivetrain between the wheels and the transfer case.
Any ideas where I should look first? 2010 L322 5.0l Supercharged
2008 L322 Vogue 3.6 VDV8 (The wife's)
Post #693900 4th Jun 2024 8:47pm
flashheart59
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Galway Green
I had something similar on my 2010 5.0 when coming off the throttle for a junction etc. Took ages to diagnose but new GKN propshaft cured it.
Post #694068 8th Jun 2024 1:38pm
