Home > Maintenance & Mods (L405) > parts to replace on service schedules
this might help members knowing what needs replacing on dealer spec service schedules,
Post #693815 3rd Jun 2024 9:45am
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I know I am probably going to get castigated... But what 'gear oil' is recommended for the Diffs in a 2016 Td6? How about the Transmission and Xfer?
Coming up on 110K - want to change them all and steele my nerves for the Front and Rear Timing belts... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #694622 17th Jun 2024 10:20pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I used the Landrover special Transfer box oil. A bit pricey but it cured the thump when turning. It's not often that a change of oil fixes something. The front cambelt apparently isn't too bad but the back, fuel pump one is a b@&!@£& I'm told. I fail to even see it so that might be a job for the indie.
Post #694631 18th Jun 2024 7:14am
