Home > Maintenance & Mods (L405) > Best alternator brand for L405 2017 3.0 diesel
ybl405
United Kingdom 2017 Range Rover Vogue TDV6 Barolo Black
Hi folks
Battery was flat after a month abroad.
AA chap said my battery is healthy but told me my alternator was playing up based on his tests.
Might also explain the intermittent HDC fault/service light that pops up 20% of the time .
Any advice on the best brand alternator?
thanks
Post #693623 30th May 2024 12:14pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Denso is OEM I think and recommended. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #693636 30th May 2024 2:36pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Re: Best alternator brand for L405 2017 3.0 diesel
If you are getting HDC Faults and the battery is not charging - Please, please, please check your ground/earth straps. The alternator may be fine or a bit stressed because of a bad 'earth'. The Earth points live behind the front wheel arch liners and if you are in a climate that uses salt on the roads... they will get eaten alive.
This is my L322 - but a similar issue. I went through 3 starters and 2 alternators in 6 months along with random cascading faults. My Indy said they would not replace a 4th starter under warranty - because my drivetrain was not grounded to the body/battery. I ran a ground lead from an old Jeep project from the lug under the bonnet down to a mounting bolt on the starter. The alternator produces the most current - the starter requires the most. My current battery says production date of 10/18 and same starter/alternator for 6 years. Also got rid of the random cascading faults.
These things have a million sensors and they all work off of a 'signal voltage' - if the signal is wrong - faults start cascading...
You can have all the juice in the world, but if the circuit is not complete... it will do no good.
Best of luck with it - JDW 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #694217 10th Jun 2024 3:57pm
