![]() | Home > Maintenance & Mods (L405) > L405 Air Con Issues |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
I guess it’s 1234yf gas, do you know what the gas pressure are reading when in use with A/C on. The best way to measure this is with the A/C mechine coupled up to gas. Read high and low pressures with engine running and a/c on. I would expect around maybe 10 bar on high side ( rough estimate without checking data).
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 150 ![]() ![]() ![]() |
It'd be useful if you posted up the live stream data as that will give useful background to any would be assistants. That'd be the standing AC off info and the AC on info, pressures and temperatures. These will be similar whether the car is on a R134a or a R1234yf charge. You can also check the air flap positions are moving with the dial settings on a scanner. |
dnt Member Since: 10 Nov 2012 Location: Gloucester Posts: 21 ![]() |
Thanks for the feedback.
Pressures are only meaningful on the day as they do vary a good amount with the prevailing ambient conditions. |
Understood.
