![]() | Home > Technical (L405) > FBH take 2! |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
A lot of diesel vehicles have an FBH fitted to provide quicker engine warm-up to reduce emissions. I've owned several diesel BMWs, a couple of Mercedes Sprinters, a diesel Honda and an Audi which all had Webasto Thermo Tops (C and V versions) fitted for just that purpose.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
I'm slightly surprised your VSE doesn't have timed climate, it can be added by setting the correct flags in the CCF.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
The above is correct - the heater unit is there to assist with a quick warm up, but if you want manual control, then it needs to be enabled/added. There's a 'how to' on this thread |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8527 ![]() ![]() ![]() |
Link to a handbook from the WIKI, it's a US version but most of it is the same... |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Chef - without going via IID, can you check the touch screen options you have. If you scroll to each screen, I think the last one, you should see a 'Timed Climate' option.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 754 ![]() ![]() ![]() |
So managed to get my gap tool transferred today, thanks Patrick, and now realise that it’s there but only to warm the engine!
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 196 ![]() ![]() ![]() |
As above. Do you not have the timed climate on the main touchscreen? 2016 4.4 diesel |
No, it’s not there! Did see on the gap Tool that I have the ability to switch it on, once Ive fitted the relevant pieces! 2014 vogue se |
