Home > Off Topic - Other Cars > L320 - Passenger Seat removal/ Plastic Floor pieces
rolemld1
United States 2012 Range Rover HSE 5.0 V8 Atacama Sand
Hoping someone can provide some guidance on how to remove these floor plastic pieces so I can remove the seat/ replace the seat cushion. Attaching pic / both almond colored floor plastic pieces are very snug, and I can't seem to find but 1 screw (for right side) to remove but it still didn't help the one side.
JH
Post #693864 4th Jun 2024 12:27am
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Lever them out - there are two or three metal clasps holding them securely which makes it quite tight to remove. Plastic tool, gently work your way around, but ultimately it needs some force!
Post #693866 4th Jun 2024 7:51am
rolemld1
Thanks for the info Ballast.
Curious when you say work around them, am I pulling UP or AWAY from the metal rails the chair sits on?
JH
Post #693882 4th Jun 2024 1:57pm
ballast
Definitely up - they're pressed down into the floor. They are tight!
Post #693903 5th Jun 2024 7:50am
