Home > Technical (L405) > factory fitted tow socket charging a battery on a trailer |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 338 |
I've got a 12v battery fitted to my ifor williams to power it's hydraulic tipping motor and a winch.
30th Apr 2024 3:09pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 387 |
Hi, it depends how you've wired it, you have both options with a 13 pin switched or unswitched.
1st May 2024 12:56pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 208 |
The "fridge" supply is enabled by a relay marked "engine run", so hopefully no chance of draining the vehicle battery and leaving you stranded, protected by a 15A fuse in the rear fuse box
2nd May 2024 8:42am |
I shall wire it up. Current
2nd May 2024 9:33pm |
