Home > Technical (L405) > Rear washer leaking through headlining
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Hi
We bought a 18 plate 405 a few months ago and the rear wiper washer has never worked
Realised there was 2 water bottles in engine bay so topped both up. Tried rear washer and didnt work, tried it again and then realised water was coming through the headlining at the rear and had ran down both sides of plastic trim
Guessing a house has or even just come off a join.
Problem is getting to it? Anyone got any idea or a how to?
Thanks
Post #691406 27th Apr 2024 10:06am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Yes pull off the rubber seal which holds the headlining down then you can get inside the headlining,
from memory, a rubber grommet holds it to the roof to go to the tailgate
You have to take the roof spoiler off to get to the pipe, a two-handed job to disconnect wires and water pipe on the spoiler, be very careful when trying to separate the rubber hose from plastic joiners/elbows
They brake Big Cry 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #691422 27th Apr 2024 2:10pm
