Home > Maintenance & Mods (L322) > Febi bilstein intake manifold quality |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 157 |
I'm looking to do the same sort of big maintenance on mine while the valve cover gaskets leak occasionally and I'm doing both LH and RH intakes just because it'll be out of my way while I have the whole thing apart.
23rd Apr 2024 6:50pm |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 63 |
I have done both sides now on my 07 3.6 and have found the Britpart ones from Island4x4 to be of good quality. You will have to remove the injectors and numbers 4 and 8 are a pain. You will need an 18mm socket on an extension (a few and swivel joint connector if you have one!) to get to the engine mounts.
23rd Apr 2024 7:43pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1367 |
I always use Febi parts. Great, good value quality.
23rd Apr 2024 10:23pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 213 |
How the hell did you get the difficult side out, can’t remember if was 4 or 8, I think it was the drivers side, the nuts for the mount were under the turbo and I could not see how the get to them, I had to split the injector in the end, massive pain in the arse, as it suddenly went and the tiny parts inside were nearly lost in the engine forever!
24th Apr 2024 9:52am |
So basically I bent some of the inner seal/panel to get a spanner on to it. Tad unorthodox but it worked for me. NSF was easier as couple of extension bars on to it and you can undo. But agreed - the OSF was a complete pain. 2007 Range Rover Vogue 3.6 TDV8 |
24th Apr 2024 4:32pm |
Ah, so that was your cheat code, I did consider doing that as I just did not have the tools needed to do it any other way, the other side wasn’t so bad once I got the extensions on it 2009 (2010 MY) 5.0 Supercharged Autobiography
24th Apr 2024 5:02pm |
