![]() | Home > General (L405) > LR service intervals SDV8 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7978 ![]() ![]() ![]() |
As far as I know, it's 16k or annually - whichever comes first & regardless of age.
The service sheets are here and confirm 16k or 12 months is the maximum time and distance. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
or stick your vin into the landrover online service history and you can see the info there.. ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6749 ![]() ![]() ![]() |
If your car is Euro 6 and has a DPF, you’re likely to find the 16,000 miles could drop dramatically depending on whether you do long or short journeys. Got - 2017 SDV8 Autobiography in Loire Blue
MalcolmLL Member Since: 21 Apr 2024 Location: Nottingham Posts: 2 ![]() ![]() ![]() |
Thank you for your responses, the car has been serviced at 1 year or 15000 miles so far, whichever came first so I'll continue this then. I thought the extortionate so and so's were just having me over. |
I used an independent once I was out of warranty. I just get it serviced every year and MOT'd at the same time - makes it easier to remember |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1160 ![]() ![]() ![]() |
I put mine in and told them just change oil and filter £295.00 overfinch modified |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Definitely should be yearly if you only drive low miles per year... Everything carries on degrading so for piece of mind most people want the car checked over by someone knowledgeable annually sir... |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1048 ![]() ![]() ![]() |
I get mine serviced every year along with MoT, every August. I’m sad enough (organised?!) to put a reminder in my diary every 1 July to remind me to book it. I average about 8k miles per year and never had dilution issues. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
LR say 16,000 miles or annually.
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 40 ![]() ![]() ![]() |
Malcolm
