Home > Maintenance & Mods (L322) > L322 MY12 - Electrical Gremlin - Advice Requested
hawkeye651
MY12 L322 4.4 TDV8 - AGP Battery 5 months old. BT IID Tool.
Repaired disconnected cables in the driver's floor wiring loom - Automatic headlights and windscreen wipers are now working correctly. GREAT!
BUT:
I then put the battery on overnight Ctek trickle charge as the doors had been open and closed a lot during the work.
Now experiencing a number of issues/changes:
The car now 'beeps' on lock and unlock which it never used to do and I did not program #possessed.
Neither glovebox - upper or lower opens.
Parking sensors both front and rear are now inoperative.
Errors on IID Tool - cleared and reappear with associated yellow warnings on the dash.
B1B36-96 (2F) - Front right outer sensor - Component Failure - internal failure
B1B40-96 (2F) - Front left outer sensor - Component Failure - internal failure
C0037-14 (AB) Rear left wheel speed sensor - General electrical failure - circuit short to ground or open
U0415-68 (AF) Invalid data received from ABS control module - Algorithm based failure - event information
U0415-81 (AF) Invalid data received from ABS control module - Bus signal/message failure - invalid serial data received
U0415-00 (2B) Invalid data received from ABS control module
U0417-81 (AF) Invalid data received from parking brake control module - Bus signal/ message failure - invalid serial data received
U0128-00 (2E) Lost communication with parking brake control module
So some notable electrical gremlin(s) - having read various threads I thought possibly start with ABS earth sensors in the front wheel arches?
Any thoughts/advice would be much appreciated. 2012 L322 4.4 TDV8 - Current
2012 AM Rapide - Current
2009 Discovery - Gone
Post #690921 19th Apr 2024 3:37pm
hawkeye651
Test drive with IID Tool - culprit is becoming clearer - just need to track down where the fault lies.
Post #691025 21st Apr 2024 11:02am
Re: L322 MY12 - Electrical Gremlin - Advice Requested
Wrong model I'm afraid sir...Your referring to an L405 for earth points under wheel well covers...
Post #691065 21st Apr 2024 11:10pm
GraemeS
You might want to recheck your wiring repair in case you've mismatched a couple of wires.
Post #691067 22nd Apr 2024 2:29am
hawkeye651
Thanks Graeme,
Having rechecked the ABS sensor and the connections on the harness around the fix. I had a look at the connector just upstream from the repair. Wondering whether I had dislodged one of the pins. Opening up the connector there was clearly some corrosion.
A quick brush up with a toothbrush and some contact Cleaner and a bit of jiggery-pokery and all is back well again with (currently) no warning lights on the dash or on the IID tool!
So thatโ€™s automatic headlights, automatic wipers and even the satellite GPS has come back online! Although it was a protracted exercise!! ๐Ÿ˜‚ ๐Ÿ™ˆ
Post #691554 29th Apr 2024 5:19pm
