Home > Maintenance & Mods (L405) > O/S/F Lower suspension arm needs replacing |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 166 |
I had the same issue a few weeks back. I only changed one as there was very little wear in the ball joint itself. After fitting my steering wheel was slightly off centre so had it tracked as a matter of course. It wasn’t that far off to be honest but they corrected the wheel back to centre. Down to personal choice in my opinion but I’m happy with just doing one. 2016 4.4 diesel |
13th Apr 2024 6:38pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 124 |
did you use genuine parts? The garage I usually use only fit genuine parts and I have been quoted £366.26 to do just the one side, does that sound reasonable? I know it is something that I could probably do myself but having recently had substantial surgery to my shoulder I doubt I could manage it 1 handed! |
13th Apr 2024 6:44pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 95 |
There is atube video on someone replacing their front lower control arms and it doesn't look that bad a job if you can get past the high torque bolts on tight areas. It took him half a day so with dealer labour I'd recon under £400 fitted has to be a bargain. |
13th Apr 2024 8:02pm |
I bought mine from advanced factors. Then did it myself. It only took me a hour and a half that’s doing it on the driveway,so with access to a ramp or pit should only take about a hour to do one side
14th Apr 2024 6:57am |
Thanks guys, I feel better about not being able to do it myself at the moment and reassured that I am being quoted a reasonable price. |
14th Apr 2024 11:45am |
