Home > Maintenance & Mods (L405) > l405 rear seat
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
l405 rear seat
Hi Guys, I have a problem with the passenger rear seat not working the small one works okay but the left will not move.
I have checked the fuse in the rear compartment number 13 15amp as the book says but that is okay.
I can move the front passenger on the seat back button.
Any thoughts? 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #690412 11th Apr 2024 3:40pm
Tinman
Bump, anyone? 2017 SDV8 4.4 silicon silver AB
Post #690449 12th Apr 2024 6:17am
is the front passenger 'forward' enough when you try the rear seat. ... - .- -.
Post #690450 12th Apr 2024 6:36am
MonkeyMan
I had the same issue which luckily was a software bug. Move the front seat all the way forwards, then all the way back, and if you are lucky the rear seat will start working again.
Post #690458 12th Apr 2024 8:04am
Tinman
I will try that Monkey man, thanks could be that as its had yet another update Big Cry 2017 SDV8 4.4 silicon silver AB
Post #690474 12th Apr 2024 11:17am
