Home > Technical (L322) > 4.2 SC - Misfiring on bank 1, seeking assistance. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 886 |
It's your sc coupling going or the bearings and the nock sensor is picking it up and registering misfires when it's not. Here is my issue same engine
10th Apr 2024 6:58pm |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 |
Thanks for the idea Dave, unfortunately don't think this is my issue. SC bearings all fine and checked for play when I removed it to do injectors. It's not just a detection issue, it's definitely misfiring. A bearing would get progressively worse over time, whereas this has been more of a step change. Appreciate the info and glad you got to the bottom of your fault. |
11th Apr 2024 9:44am |
Fingers crossed you get it sorted these are a for misfires, have you looked at the pcv yet ?? You can block.it off and see if anything changes I see you smoke tested it I did the same and found a small leak behind the throttle body where a plastic pipe pushes into the head the O ring there had failed also causing misfires. Common problem.
11th Apr 2024 10:14am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Cam shaft sensor jumps out at me as being cause |
11th Apr 2024 11:20am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1349 |
I'd agree with the cam sensors as a possible place to check too. If the sensor is giving duff infomation to the ignition system, then it could lead to mis-fires.
11th Apr 2024 4:44pm |
Thanks for the replies chaps. I have looked at the PCV and had it off with engine running, didn't cure the misfire and appears to be working correctly.
13th Apr 2024 5:30am |
