Home > In Car Electronics (L322) > Radio system wiring plugs
rik__
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi Guys got in the otherday after all the rain to discover a dead screen on the radio, had a look and small amounts of water in the system, removed as much gear as i could (1 module i could not get out)
Does anyone know how this ones comes out (please dont say i have to remove the boot floor)
after electrical cleaning everything i could reach, i am left with some left over plugs (cannot for the life of me remember if they were plugged in to start with or just spare harness
the flat plug middle right comes direct from the sat nav cd player (sat nav appears to work fine)
big white plug appears to go nowhere?
after everything i could could find being plugged back in it appears the antenna has some sort of power and its not got any (cannot pickup any stations)
also double bonus drivers side rear door speakers making horrible cracking noise so balancer doing left only (any ideas on this also?)
thanks
Post #690072 6th Apr 2024 12:05pm
rik__
Further update, it appears to be drivers door speakers (top tweeter included), drivers back door speakers and centre dash speaker when putting balancer all the way to the left the humming stops (might be related but all the controls on the drivers door have stopped working). was looking at the loom going into the door and it appears to be secured with a 10mm nut?, does that have to be undone to get the plug out? (might need to buy a new tool for that)
Post #690165 7th Apr 2024 5:21pm
mjdronfield
From memory, You need to take off the lash down loop chrome thing using an Allen key then you can undo the plastic nuts that are in the hole recesses in the black plastic boot floor cover…. Just an extra bit comes out, to give you complete access.
You can buy a “water shedder” from LR to fit behind it all so it stays dry.
The screen is driven through the sat nav.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #690171 7th Apr 2024 6:25pm
rik__
Hi mjdronfield
thank you for your reply, im not 100% sure on what part you mean, i thought you mean the plastic floor but that appears to go under every other panel in the boot
(i presume you do not mean this piece?
thanks
Post #690261 8th Apr 2024 6:26pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Correct, that bit. It’s quite easy. You can gently lift the other panel so you can slide the plastic bit out. It all comes apart really easy - I’ve just stripped the whole lot out and put it back again
Post #690272 8th Apr 2024 9:09pm
pcourtney
Try to replace the SatNav CD system with a BMW MK4 DVD GPS unit ( DVD ROM Drive ) , then you can enter a UK postcode on the screen ( only the MK4 model can do this )
https://www.landyzone.co.uk/land-rover/200...de.241877/
Post #690274 8th Apr 2024 9:30pm
rik__
Thank you all for your reply, in my effort to try and sort this car I again have made it much worse, cleaned up all the electronics but think I have some of the arials in the wrong place maybe some other cables aswell sat nav on road and off road missing from radio menu and opening any door other than drivers makes a very loud buzzing (almost like an alarm)
Post #690575 14th Apr 2024 12:07pm
rik__
Ok so it turns out it was the driver side speakers again, unplugged them all and the noise has stopped, do you know if rave has a pin out for all the electrical systems in this car. think im going to have to look and test everything
Post #690621 14th Apr 2024 7:21pm
rik__
Anyone seen the sat nav (on road and off) just disappear from the menu, i double checked the cd player has power and it reads and ejects the disc no problem
Post #690987 20th Apr 2024 5:47pm
rik__
well some good news ive found were the water is coming in
now i think that clip is for the pillar, i wonder if i could rip it out and seal it and just live without that 1 fitting
Post #691454 28th Apr 2024 10:23am
