Home > Technical (L322) > UK trailer wiring harness on US 2004 L322?
ssmlr322
United States
I’m wondering if I can install this UK trailer wiring harness on my US 2004 L322:
https://www.island-4x4.co.uk/towing-electr...-8061.html
They say it’ll work with up to 2006.
Questions:
Is the vehicle electrics where you install the harness identical between US and UK on a 2004 L322?
Is there any issue in converting from the 13-pin connector to US 7- or 4-pin connector?
Any other gotchas? I don’t know what I don’t know
(Why am I considering this? Because I desperately need to find a wiring harness and none seem to be available in the US for my rig.) 2004 RR HSE 22k miles
2006 Audi A6 Allroad twin turbo
Post #689990 5th Apr 2024 2:14pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
https://parts.jaguarlandroverclassic.com/y...trics.html 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #689991 5th Apr 2024 2:39pm
ssmlr322
United States
Thank you! I guess they provide all the possible options for the different countries. I've contacted them. 2004 RR HSE 22k miles
Post #689998 5th Apr 2024 3:06pm
wayneg
I have had a 2003 and a 2007 in Australia and both had factory harnesses both wired totally wrong for Aus. I had to rewire both and run an electric brake trigger from the LCM in the rhs footwell to the EB controller then a wire to the trailer plug. Only other issue is the car will send test pulses to the trailer lights which will flash if they are led. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #690057 6th Apr 2024 9:52am
