![]() | Home > Maintenance & Mods (L322) > Squeaky Rear Seat? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
The big rear seat makes a hell of a racket, squeaking and rattling away. No noise when folded up for load space. Seems a bit of the squeaking comes from where it rubs up against the trim by the door pillar, but the rest is "inside". Sitting on it helps the noise to go away.
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I have the same issue, although not spent much time trying to sort it. Only thing I did try was treating the leather to try and soften it. Made no difference as it sounds as though it's coming from inside the side leather trim. FFRR TD6 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
same as greg, tried softening the leather with rub..its not so bad now but gets worse in the winter.. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
On the FRONT seats there is a bit of soft plastic trim that fits on the hard plastic surround and isolates it from the leather, mine was missing on the drivers side - I bought one and fitted it only £6 - job done. However prior to this and so it should work on any plastic to leather interface I bought a tube of clear silicon grease from an electronics shop smeared it on and silence.
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
good tip ![]() mike. |
Thanks for all the tips.
Not messy at all, just make sure you don't put any where you sit, would make your jeans or suit shiney |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Am i missing something here , "Squeaky rear seat" when you are doing what on it ! Far to many gone... |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had this issue as well, in my case it was nothing to do with the leather, what I found was that the rear seat catch was causing the squeeking so I dropped the seat forward and wrapped a couple of layers of insulating tape around the bar that the mechanism locks onto - job done, squeeks all gone......I'm sure you'll find this is the issue..... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Obviously the rear seat needs exercising more often |
It does go up and down a lot |
i'll try this next time... ![]() |
Finally sorted this out with a couple of turns of black duct tape around the upper and lower latch bars on the rear seats, so thanks to CG-SC |
good to know this.. |
