Home > Maintenance & Mods (L405) > Battery Health
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Battery Health
Hi guys took some reads of both batteries with GAP tool as local garage advised me my battery may need changing soon but everything is ok no issues starting etc.. Are the readings what they should be expected when running and engine off.
 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #689581 1st Apr 2024 1:35pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
You'll know your battery is on its way out when the stop start feature no longer works which is well before when the battery finally dies.
Post #689651 1st Apr 2024 8:53pm
jaysta10k
Apparently my MY 14 doesn’t have the stop start feature. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #689653 1st Apr 2024 8:56pm
Gremlin500
………….. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #689654 1st Apr 2024 9:17pm
garyRR
If you have a means of testing CCA output of a battery, I find this gives a very reliable indication of battery condition and where it is in its lifespan.
If, after a recovery programme with a smart charger, CCA is 60% or below original CCA stamped on the battery, the battery is near end of life.
80%+ all good.
70% still healthy but a year or two remaining life. 2015 Range Rover Autobiography 4.4 SDV8
Post #689780 2nd Apr 2024 9:07pm
Gremlin500
………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #689787 2nd Apr 2024 11:32pm
