Home > In Car Electronics (L322) > Infortainment system dead no light in switch (Now sorted)
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Good afternoon
After my woes with the fuel pipe, I decided to fit the used DAB module that I bought from eBay. The iid tool showed an internal fault in the module currently fitted in the car.
I swapped them over but did not bolt the replacement unit in, went to the radio, tuned the stations, and it all worked, I have DAB.
Set about bolting everything back in the boot and after all was back together, I thought I would set my favourite DAB stations.
Nothing..... no screen, no light showing on the on and off knob, completely dead.
Could low battery maybe cause this because I had the boot open for quite a while? or maybe a fuse/relay issue. I can't understand how one minute it is fine and half an hour later it is dead.
Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689234 28th Mar 2024 3:20pm
Buellie
Forget the above post please.
Been out half an hour later and I have DAB all working. As I was tuning my favourite stations I got a low voltage shutting down message from the system.
So happy that I have DAB and it sounds great, but have a non-running car because of the fuel pipe issue in this thread.
https://www.fullfatrr.com/forum/topic69700.html Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689241 28th Mar 2024 3:55pm
