Home > Technical (L322) > Which diesel?
RovingCanary
I use the cheapest Diesel, never tried premium but wouldn't think it will make a difference.
I put premium petrol in motorbike, as its pretty old, that makes it run better, and as its E5 its less likely to go stale when it's sitting over winter.
Post #690334 9th Apr 2024 9:13pm
Bazm
Switzerland 2007 Range Rover HSE TDV8 Oslo Blue
A quick update.
When I bought my RR, TDV8, 3.6, I did a 300km run home and averaged 9.6ltrs/100kms (29.5 MPG UK).
I ran some injector cleaner through the car using 1 ltr to around 40 ltrs Diesel. Did the same 300km run driving the same way and averaged 8.3ltrs / 100kms (34 MPG UK).
I did notice the car feeling a bit more responsive and smoother. Seems the injector cleaner had some positive effect.
I'll be using premium fuel if it's available, and using injector cleaner every few thousand kms.
Post #690535 13th Apr 2024 6:46pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Can I ask what brand of injector cleaner that you used. I think I will try some in mine Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690537 13th Apr 2024 6:49pm
Bazm
I Used FACOM as that was what was available and least expensive. 30 Euros for a litre if I remember correctly.
I did read the ingredients of the various cleaners available in the shop and they were all very similar (not that I'm an expert in this)
I have found it is better to use a high concentration. 200ml in a full tank will have a negligable effect.
A full litre for under half a tank seemed to work for me.
Hope it works for you.
Post #690543 13th Apr 2024 7:12pm
Buellie
Many thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690548 13th Apr 2024 7:48pm
