Home > Maintenance & Mods (L322) > How do I remove these?
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I’m trying to sort out my fuel gauge and get the not he tank senders
I have cut the carpet to move it out of the way but need to get it from under these side panels. The bottom just pulled away but how are they fixed at the top?
Many thanks
 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689049 26th Mar 2024 3:07pm
JayGee
I nearly had to do this on Sunday to get better access to the top shock mounts but managed without. I think you need to pop the airbag plate at the top of the C pillar and there should be a screw under it like there is on teh A pillar to remove the trip to access the bolts which old the top of the lower part. 2012 TDV8 Vogue (L322)
Post #689054 26th Mar 2024 4:28pm
Marcus76
2006 Range Rover HSE 4.4 V8 Alaska White
Hello,
Just pull the c-pillar away there will be two screws for the lower part. It’s a bit tricky to get the plastic pillar back on the belt screw .
Excuse my english
Marcus
Post #689063 26th Mar 2024 5:15pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #689073 26th Mar 2024 6:24pm
Buellie
Many thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689078 26th Mar 2024 6:50pm
