![]() | Home > Camping, Caravanning and Holidays > Towing over 2000kg |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7890 ![]() ![]() ![]() |
No expert here, as I don’t tow, but looks like the only thing they are trying to avoid is the gearbox getting hot, if you can live with the start not being “smooth”…. I agree, does seem a bit of a faff. I’ve not heard anyone on here say they set off in low range.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I think it means if you're doing a lot of slow speed towing use low range.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1399 ![]() ![]() ![]() |
There will be others on here with much more experience of towing, and in particular of towing heavy loads, but I have tended to use low ratio only if I thought the car was having a bit of a struggle (e.g. hill start with 3.9 Classic towing double axle trailer wider than the car and full of wet logs) or if I wanted greater control in slow speed manoeuvres. It's probably better to use low ratio if towing on a poor surface off road, e.g. car struggling to find grip up a muddy hill.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 105 ![]() ![]() ![]() |
I have towed over 2 tonnes (triple axle stock trailer full of hay bales) without using low range and not noticed any non-smoothness.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 607 ![]() ![]() ![]() |
I've regularly if infrequently towed well over 2 tonnes with each of my FFs. Either some sort of plant (digger/chipper/tractor) on a plant trailer or a car on a car trailer. Indeed I've rarely towed less than 2 tonnes unless I'm on a return journey with just trailer and no load in which case its easy to forget you're towing at all.
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 ![]() ![]() ![]() |
Thanks guys for all the replies, very useful indeed!
Actually I do up the pressures for higher load yes...they're on the door jam. Mike - MPx
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7989 ![]() ![]() ![]() |
I've towed various trailers, some quite heavy, including up mountain roads and never felt the need for low range.....
42psi on rear tyres for towing, as opposed to standard 37psi. Only Range Rovers since 1988 |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
Towing a 2.5 tonne caravan fully loaded up long steep hills in the peak district and my 4.4V8 never even changed gear, let alone ratio |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 778 ![]() ![]() ![]() |
i have forgotten how to engage low range RR 2005 4.4 petrol
Thanks to you all for the replies. My first day towing my recently purchased trailer was a success, never done it before. One thing l will have to practice though is reversing a trailer, was rubbish! |
