Home > Technical (L405) > No crank unless battery disconnected and reconnected
Needmorepower
Ireland 2006 Range Rover Vogue Td6 Orkney Grey
Hi guys just picked up a 2017 sdv8 AutoB.
Bought as a non runner but started right up on new battery HOWEVER.. But etc It will start everytime with say a 10 min window but if left longer sometimes it wont crank at all ( all ign lights etc are on )
Disconnect the battery and then reconnect and she'll fire right up.
Have few codes coming up but nothing relating to this.
Anyone gime a steer before I loose my last few hairs?
Thanks in advance Thumbs Up
Post #688983 25th Mar 2024 8:44pm
Gremlin500
………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688989 25th Mar 2024 8:53pm
Needmorepower
Thanks Yes checked earths by running heavy leads to chassis.
Both Batts showing full and she cranks strong after batt in disconnected for few seconds.
telematric codes... back up battery failure
" " " parametric
U0080-81 vehicle comms bus f- invalid serial data received
u2300-56 central config invalid/ incompatable config
Post #688991 25th Mar 2024 9:07pm
Gremlin500
……… “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #688998 25th Mar 2024 10:02pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Is it possible that you have a faulty BMS module? Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #689053 26th Mar 2024 4:15pm
