![]() | Home > Technical (L322) > tdv8 4.4 restricted performance turbo..SOLVED! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1292 ![]() ![]() ![]() |
I thought the main turbo only has variable pitched blades that does the self test movement. Unless anyone knows better. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Maybe I should get under the other l322 (that’s currently fine) and compare the noises/observations. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 69 ![]() ![]() ![]() |
As Kevinp says,the primary turbo on the right hand side only has a variable vane mechanism, which can be tested by cycling the ignition on and off. The left hand turbo is fitted with I think what is called a turbine shut off valve. This is vacuum operated, and directs exhaust gasses to the turbo when required, |
SOLVED!
Very satisfying. |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Where are those diagrams? I’ve looked and cannot see them… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 44 ![]() ![]() ![]() |
Sounds a bit like the YT of LRTime when he got his new405 "The Queen "
