Home > Technical (L322) > po40d-00 2b new owner |
L3FF Member Since: 22 Feb 2024 Location: UK Posts: 4 |
See garyRR's response ('Thankfully many problems on the 4.4 TDV8 tend to be the same ones'): https://www.fullfatrr.com/forum/post637247.html
25th Mar 2024 7:44am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
For information; I had my Indy replace the lower exhaust gas temp sensor last time it was in for another job as I was getting the P040D error ( I think mine was the 2f error sub code ). Any how this is the lower sensor near the DPF which @GaryRR has written the “How to” about changing.
25th Mar 2024 10:14pm |
miketrike Member Since: 24 Mar 2024 Location: birmingham Posts: 12 |
hello ..thanks for reply... but im still not sure which sensor my code refers to...any idea where this 2b sensor locates,, fyi my tdv8 4.4 runs great but throws up this code po40-002b also throws up wheetone wheel left rear..i clear them with gap tool ..and they return at some later point but now immediately..car says no faults ...lights on dash and then these two codes....oh another question if you dont mind..how to search wiki workshop manuals ...any idea ? thanks mike |
26th Mar 2024 12:36pm |
