![]() | Home > In Car Electronics (L322) > Bovee or Invery |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Aside from the name on the front, they're the same. 2015 Range Rover Autobiography 4.4 SDV8 |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 148 ![]() ![]() ![]() |
Many thanks Gary, I did not know that. I have bought an Invery on sale on their website yesterday for £62 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
StephenO Member Since: 18 Jan 2016 Location: Lochinver Posts: 21 ![]() ![]() ![]() |
I recently purchased a Bovee, I did consider the Invery as it was a tenner cheaper but I read somewhere that the Invery doesn’t show the song title on the screen. Maybe you could let us know if this is the case |
I’ve had both and it depends if you are Apple or Android. Bovee is older tech and you are limited to a very basic Bluetooth codec on Apple and you may have some connectivity issues but is fine with Android. If you have Apple I’d go with Invery. 2012 TDV8 Vogue (L322) |
Thanks I do have apple and have bought the Invery one Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
Good price for Inveray |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
I've the Invery, its shows the song title on both my android and iPhone and what I will say about it is the connection is very solid, very strong and it connects perfectly without intervention almost every time. I think in 4 months I had to manually select the BT once or twice. Current yokes
My new Invery has arrived and I have it connected. It does show the tracks on the display when connected to my iPhone 14 and works very well.
Not sure about Invery but with the Bovee you can change tracks with steering controls |
Cheerrs, I thought they are the same so it should be able to I believe. Hopefully someone will come along that has the Invery and can confirm.
My Invery allows me to skip tracks on the steering wheel and the infotainment unit. Its a 2012 so maybe different software.
Thanks it is all working now, just unplugged and plugged in again Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
