Home > Technical (L322) > L322 4.4 TDV8 service required reset
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
Hi all,
I have read many threads regarding this. I am trying to reset the SERVICE REQUIRED message when the engine is started. It had a major service and MOT yesterday.
(NB I used the forum to research how to get the oil level indicator to show the new oil level after the service. The engineer couldn't do it. (In the service menu it said OIL LEVEL NOT AVAILABLE). It was the bonnet open, ignition on (not the engine) go into the service menu, select oil level, then double press the cruise control cancel button twice hack. Sorted!)
Weird.....
Anyway I have tried the hack I found on here for the service reset. (bonnet up, dvrs door open, press the brake and accelerator at the same time, and this resets the service indicator.
Only it hasn't ????
Your thoughts please,
Steve 4.4 TDV8 Sumatra Black + Ivory Leather
Post #688579 21st Mar 2024 9:48am
a GAP iidtool will sort it... ... - .- -.
Post #688594 21st Mar 2024 11:29am
DrRob
You need a plug in to reset it.
Take it back to the garage and kick their Censored
Also sounds like you need to use a different garage Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #688606 21st Mar 2024 1:20pm
EOD Steve
Popping back to garage in the morning.........
Post #688615 21st Mar 2024 2:13pm
