Home > Technical (L405) > TDV8 to SDV8 Transplant
Needmorepower
Ireland 2006 Range Rover Vogue Td6 Orkney Grey
Hi guys have a 2014 l405 with the sdv8.
Suspected engine damage due to turbo failure.
I'm struggling to find a decently priced sdv8 engine but my question is , would it be doable to convert a TDV8 to work? and would it be worth it?
I know block and heads are the same so is it it just electrical and pumps and turbos are different?
Any help greatly apprisiated.
Cheers
Post #688324 18th Mar 2024 9:20am
GraemeS
The sumps are different but can be swapped. Another member fitted a new SDV8 to his L322.
Post #688326 18th Mar 2024 9:48am
Needmorepower
Thanks for that but is there not more different? sdv8 has more power. ?
Post #688327 18th Mar 2024 9:52am
GraemeS
Only a very slight increase in power of the margin often seen in a model upgrade with improved tuning. The TDV8 was only in the L322 for 2 years so a minor tune update for the L405 wasn't unusual.
Post #688367 18th Mar 2024 8:47pm
