![]() | Home > General > FFFR Creaking and Groaning |
Just over the last few days i have noticed that when turning either left or right there is an annoying sound which i can only describe as a creaking and groaning sound coming from the rear end of the car , kind of like rusty springs sort of noise ….
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Your wallet is jammed between the bodywork and the exhaust |
As above, rear suspension bush. The rubber creaks when it dries out - dealers are renowned for spraying with WD40 to "cure" the symptoms for a few weeks. Replacement is the only permanant cure, but you can probably put it off till next spring as the noise will go away in the wetter/cooler months. |
Cheers guys |
