Home > Technical (L405) > Battery charge life
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Battery charge life
If I leave my 405 in an airport Car park for a month, will my battery be OK on my return. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #687865 12th Mar 2024 1:47pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
If you have access to the LR Remote app one of the options is to put the car in low power mode for a set date which would protect the battery from discharging but I don't know how old your battery is or if it has a history of problems, If its in good condition and you can use the low power mode you should be fine.
I have left mine for a month over winter (in my garage) in low power mode and it still had 80% on my return. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #687866 12th Mar 2024 1:56pm
if you have a breakdown cover then dont worry about it ...also i believe most airport parking sites have someone who will jump start you.. ... - .- -.
Post #687876 12th Mar 2024 3:23pm
GrandadRob
Many thanks 2013 SDV8 4.4 SE Luxor.
Post #687877 12th Mar 2024 3:27pm
garyRR
Personally, I'd get a Noco GB50 and shove it in the spare wheel well fully charged. That way, if you ever need a jump start, there's 0 inconvenience. 2015 Range Rover Autobiography 4.4 SDV8
Post #687899 12th Mar 2024 7:33pm
