Home > Technical (L322) > Module function? XUI500250A
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Anyone know the purpose of this module?
It's located in the upper right side of the rear tailgate.
On the opposite side this module is located (key fob receiver?)
Both are connected to the heated windshield. 2007 L322 3.6 TDV8 Stornoway
Post #687790 11th Mar 2024 12:35pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I think they're related to the radio aerial, interface modules, pre amps etc. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #687793 11th Mar 2024 12:44pm
S.Hafsmo
I ask because i recently replaced my upper tailgate with a rust-free one from an earlier model. The latter tailgate did not have the provisions to install the right antenna/amp. Now, it might be unrelated, but after I installed the new tailgate without installing the right unit, my key fob only works intermittently, and it almost seems to be switching between receivers, as it always works first time in the morning, but rarely when i get out of the car at work. If I wait a few minutes, it works just fine. 2007 L322 3.6 TDV8 Stornoway
Post #687840 12th Mar 2024 5:47am
AndyRoo
This guy seems to have the same problem as you, seems to be water.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #687901 12th Mar 2024 7:54pm
