Home > Technical (L322) > Rear number plate lights L322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
first thought would be the fuse, second would be to take the tailgate inner panel of and have a look at the wiring..panel is very easy to get off. |
30th Jul 2011 9:23am |
Doesn't your display a light error when you startup and get out? I know when my i put LED's in mine the bonging was constant untill i put the ones with resistors in. That might indicate something more than a duff bulb. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Jul 2011 9:48am |
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 |
Hi Scarey thx for the reply
30th Jul 2011 10:19am |
And no there are no bulb warnings showing This is confusing me also |
30th Jul 2011 10:20am |
by coincidence i've had my reverse bulbs out this week and they are definitely 12 volt 6 watt jobbys..cant understand why you're only 6 volts there.. |
30th Jul 2011 10:59am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
If you only have a maximum of 6v you have a bad connection somewhere.
30th Jul 2011 11:07am |
I been looking at it for a couple of hrs today and I'm still none the wiser
30th Jul 2011 5:27pm |
Does anyone know if there is a fuse for the number plate lights because I can't see anything relevant in the manual ?
31st Jul 2011 1:41pm |
Have you looked at the sticker on the back of the fuse box? Im sure it has more fuse locations than in the manual. I will look at mine tomorrw and see. Currently in work with the wife's car. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
31st Jul 2011 8:06pm |
Thx Rob I have looked but maybe I just can't see it
31st Jul 2011 8:24pm |
dont think it is a fuse ..if it was then you wouldn't get any voltage coming through..as a temporary fix you could very easily run a feed from the side lights to the number plates lights.. |
1st Aug 2011 6:47am |
Thx Scarey I think your right I have just asked LR no fuse so now I need to recheck wires and earths oh joy lol |
1st Aug 2011 7:47am |
Right pretty sure I know the problem after a lot of investigating
1st Aug 2011 7:38pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Jon you keep breaking it LCM is in the drivers footwell and I have never found water in there or any other part of the interior Both bulbs were working as I checked everything electrical regularly, glad to hear headrest was an easy fix Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
1st Aug 2011 9:16pm |
