Home > Technical (L322) > Lost connection with steering angle sensor module. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 535 |
Hi, could you confirm whether grating noise is coming from the brakes themselves when you apply pressure on the brake pedal or whether the grating noise is coming from the pedal area itself.
1st Mar 2024 1:18pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
I am wondering if you have a worn bush or linkage somewhere on the suspension assembly. At certain angles under braking or load it will may feel like grating but in fact be wobbling as well as throwing your steering angle sensors.
1st Mar 2024 8:37pm |
Ham Member Since: 29 Jan 2022 Location: Stara Zagora Posts: 4 |
Thanks guys,
2nd Mar 2024 8:58am |
