Home > Technical (L405) > REstricted performance and sounding like an old taxi
comports
Evening all,
I posted a few weeks ago about restricted performance a few suggestions came back (thank you as always) - of which I checked and could find nothing obvious.
This even it happened again - but with one notible difference.
I did a little 'spirited' acceleration (cos I love the 4.4 pick up from 20mph to 'just shy of 70' <cough>) while joining a dual carriageway and all was normal. I eased off and naturally slowed to turn off at the next junction when up popped the Restricted Performance symbol again - but then I hear pretty loud 'tappety' type noises under gentle load - I can only describe it as as old taxi with no oil.. Shocked
Pulled over to safe place, turned it off and got out for a quick look - I couldn't see anything obvious so, wanting to limp home, i started the engine again and all was fine... no restricted performance, normal power etc etc.
I drove about 3 miles home (gently) but no messages, nothing... Unfortunately i have developed fault with my IID BT although last time I got restricted perf there were no codes saved to give me any clues.
Has anyone experience the 'old taxi' tappety noises and can suggest what I might need to do to investigate?
Many Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #686836 29th Feb 2024 11:08pm
comports
just to add, before it happened again today I did pull the faults codes via IID but the only thing I got was this one. Last time I got the performance issue I obvioulsy turned the car off - in doing so it cleared the fault and there were no hard faults stored - this makes it quite difficult to find a clue to the issue.
It might be totally unrelated but though't I'd post just in case. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #686843 29th Feb 2024 11:44pm
