Home > Maintenance & Mods (L322) > Transfer box fluid change |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
That isn't correct and you could end up blowing your transfer box. The diffs and transfer box are exact fill only, not to the plug.
26th Feb 2024 11:55pm |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
The front and rear diffs must be filled with the correct quantity of oil as stated in post number 2 but the transfer box is filled to the level plug. Below is a direct quote from the workshop manual.
27th Feb 2024 3:07am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 811 |
Thanks Gents
27th Feb 2024 7:56pm |
Yes maybe a slight difference in interpretation. The workshop specification says either a wet or dry fill is 1.5L, which should take the level to just below the fill plug, which is what the workshop procedure states.
27th Feb 2024 9:15pm |
I just checked with Andy from Glenrands.
28th Feb 2024 10:42am |
