Home > Maintenance & Mods (L322) > 2002-2006 Key into Flip Key
Page 3 of 4 <1234>
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
they often want to sell bigger quantities.
Talk about a sample order with them you may can order only 5 pieces. (I would take one)
Post #77019 22nd Aug 2011 5:53am
dan_uk_1984
I asked them who their regional dealers are, so I can buy from them instead - they didn't reply.
Frankly I'd rather keep my horrible key than give those a-holes any of my hard earned cash Evil or Very Mad
Post #77045 22nd Aug 2011 9:46am
3R10
France
hey dan, check this out
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...0628228122
it looks like this is the one needed! 2000 BMW M5, Avus Blue/LeMans Leather Interior
2006 Range Rover Westminster Java Black
Post #77075 22nd Aug 2011 12:22pm
Stryke
Ok, so say I get this key, get it cut...
Does the dealer have to code it? Confused
Post #77078 22nd Aug 2011 12:36pm
dan_uk_1984
It's not that key - that ;s just the case. No internals :'(
Post #77079 22nd Aug 2011 12:39pm
BrianC
is this what your after ? http://www.ebay.co.uk/itm/Land-Rover-Range...19c8661ccc
Post #78164 29th Aug 2011 9:13pm
pretlove
i think the ignition is in a differant place on the 2007 model so i doubt that would be any good "RANGEISM WILL NOT BE TOLERATED"
Post #78167 29th Aug 2011 9:16pm
dan_uk_1984
Fraid not, already checked that out... Getting the key to turn in the lock is never the issue, or even unlocking the doors.
The issue is the transponder chip programming. I've phoned a lot of companies over the last week or so who say they can "clone" the transponder chips, but whenever you say "Range Rover" they have all said they cant do them Sad
If you were prepared to sacrifice your original key you could get a flip key, but it's a bit risky.
I "think" the immobiliser/security module is different with the flip keys, but haven't had time to 100% verify this.
Post #78170 29th Aug 2011 9:18pm
pretlove
id be willing to scrifice one of my keys to try this out ....so what would i need dan in order to do it "RANGEISM WILL NOT BE TOLERATED"
Post #78171 29th Aug 2011 9:21pm
oodathort
I did this using the BMW diamond key and a flip case of ebay
Post #78196 30th Aug 2011 6:47am
dan_uk_1984
oodathort wrote:
I did this using the BMW diamond key and a flip case of eBay
I looked at that option - however it's never going to look great. It's still a BMW key inside a cheap aftermarket case.
Personally I prefer the idea of the real deal. Otherwise I don't see much point myself.
Post #78201 30th Aug 2011 7:22am
oodathort
I agree but what you can do is remove the three micro switches mount them in any format you require for your new fob and you dont ruin your origional key this gives you the option of using various fobs
Post #78204 30th Aug 2011 7:30am
Well to add to this i am keeping my eye on the bay so as to buy a cheaper newer style key, maybe even a disco 4 one, and an older key that still works and mix and match both of them to get a nice new flip key.
Its not perfect for the disco 4 option as the key doesn't flip out as easy as a normal flip key being a smart start system but im sure given enough time and fiddling something could work but the newer style key still looks good Smile
Post #85080 2nd Oct 2011 10:21pm
daveo
i have tried several times with a few flip style keys and they will not programe to the bmw cars,i.e open and close the doors, the bmw diamond key will but you are back to the same type of key, i do know some one who can do the transponder chip, not cheap... but you could use the one from your old key,they just fall out, the key cutting is not a prob..back to programming it to open and close, you will need a remote that can clone and copy the commands. i dont think removing the board from your old key and modding it will work they are to different.
but there may be some one out there that can surprise us all. V8 facelift Range Rover Autobiography 22" wheels.
Post #85098 2nd Oct 2011 11:17pm
jammyk
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Flip key from LR dealer
All, when i purchased my car the spare key wasnt present. In the end the delares ordered my a new key and coded it. This new key was indeed a new style 'flip' key. As this was all done as part of my vehicle purchase i have no cost information.
All i can confirm is that after 6 months, the new flip style ke is working (touch wood) and ive no no issues.
If the mew key style is that important, i would suggest going via your dealer who can sort it all out for you.
Post #91414 10th Nov 2011 12:38pm
Page 3 of 4 <1234>
