Home > Technical (L322) > Range rove suspension
Gas man toopsy
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Hi I have a Range Rover L322 TDV8 and I’m having issues with the suspension, the dynamic suspension side seems fine but after replacing all levels g sensors it just isn’t level and all the Center of the hub to the wheel arch measurements are different, i have tried to re calibration of the suspension but it keeps failing!, can anyone suggest the best cheapest diagnostics to sort this out
Post #685876 17th Feb 2024 7:15pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Do you a GAP IID diagnostic tool ?
If yes, try the diagnostic suspension height calibration but at a heigth 10mm lower to see if it is accepted. Sometimes the height sensors become adjusted outside their acceptable range which generates an error in the calibration process and causes the vehicle’s control module to reject the calibration outcome.
If no, go to a good 4x4 Indy with Hunter 4x4 alignment equipment and ask for an alignment and ride height calibration. ( if you’re on the South Coast I’d recommend GlenRands for this: I had mine done there and it was like driving a different vehicle once the suspension was within spec ). TDV8 4.4 2012
Post #685884 17th Feb 2024 10:46pm
