Home > Technical (L322) > BMW era 2002 to 2005 Fuses
pcourtney
Just found this today, it might be useful to someone who has the older BMW based L322 cars
Glove Box Location
1 Instrument Cluster
2 Garage Door Opener, Heated Rear Window, Rear Blower, Rear Seat Heating, Trailer Socket
3 Fuel Cooler Fan
4 Light Module
5 Diagnosis Plug, Engine Control
6 Inside Mirror Electrochromic, Parking Aid, Tyre Pressure Control System
7 Is Not Used
8 Onboard Computer, Radio, Telephone
9 Brake Light, Light Module, Speed Control
10 Horn
11 Central Locking System, Outside Mirror, Window Lift Front
12 Air Conditioner,
13 ABS, DSC, Transmission Control
14 Is Not Used
15 Central Locking System, Diagnosis Plug, Servotronic, Window Lift Front
16 Tyre Pressure Control System
17 Outside Mirror, Passenger Lights
18 Immobiliser
19 Is Not Used
20 Adjustment Driver Seat, Steering Column Adjustment
21 Adjustment Passenger Seat
22 Telephone
23 Steering Column Adjustment
24 Central Locking System, Outside Mirror, Window Lift Front
25 Immobiliser
26 Windscreen Wiper
27 Glove Box Light, Passenger Lighting, Windscreen Washer System
28 Headlight Wipers Cleaning
29 Heated Steering Wheel
30 Electric Damper Control
31 Engine Control, Immobiliser
33 Transmission Control
34 Air Conditioner, Blower, Heated Windscreen
35 ABS, DSC
36 Is Not Used
37 Transfer Box ( Tow Operation )
38 Is Not Used
39 Immobiliser
40 CD Changer
41 Rain Sensor, Rear Window Wiper & Washer
42 Courtesy Mirror Illumination
43 Thiefproofing System
44 Airbag
45 Instrument Cluster
46 Instrument Cluster
47 Heated Spray Nozzles, Heated Windscreen
48 Is Not Used
49 Navigation System, Onboard Computer, Onboard Monitor, Radio
51 ABS, DSC, Fuel Pump, Secondary Air Pump
50 Is Not Used
52 Front Seat Heating
53 Engine Control
54 Transmission Control
55 ABS, DSC
56 Is Not Used
57 Air Suspension
58 Sliding / Tilt Roof
59 Auxiliary Heater Diesel, Independent Heater
60 Central Locking System, Window Lift Rear
61 Main Fan
62 Secondary Air Pump
63 ABS, DSC
64 Blower
Rear Boot Location
74 Trailer Socket
76 Trailer Socket
79 Heated Rear Window
80 Rear Window Wiper & Washer
81 Rear Seat Heating
82 Rear Blower
84 Central Locking System
85 Fuel Pump
87 Trailer Socket
88 Air Suspension
Post #685651 14th Feb 2024 10:10pm
pcourtney
Normal current drain on an L322 is 20-30mA
Possible fuses to remove with regards to battery draining too fast over 7 days
Fuse 12 HEVAC Starts off at 1.28a Drops to 0.82a after 10secs then sits at 0.26a
Fuse 22 Telephone
Fuse 28 Headlight Wipers ( if you have them )
Fuse 49 Sat Nav System
Post #686439 25th Feb 2024 5:48pm
