| L322 4.2 SC 2007 Exhaust Manifold | |
Morning all,
I have quite the ticking noise coming from the passenger side of the engine. It is worst when cold then gets slightly better as it warms up. This has been diagnosed as the exhaust manifold leaking.
Two questions on this, struggling to find info on.
1) Does anyone know the part number for Gasket/ Studs/ even the manifold if it has warped? I can’t seem to find them listed on the usual suppliers I would use.
2) Has anyone undertaken this task themselves. I seem to have conflicting views on how it is done. Workshop manual states a lot has to be removed in order to access whereas others have said you can access from underneath after dropping the rest of the exhaust.
ATB,
MA
