![]() | Home > Technical (L322) > URGENT advice please; battery empty and 1000km tomorrow |
You shouldnt get inactive EAS or anything from a flat battery, as long as you reset the steering angle sensor by turning the steering wheel full lock to lock everything else should fire up as normal.
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
Thanks Dan,
If you do find you have a drain it is more than likely the final stage blower resistor.... Does your fan sometimes work and sometimes not work? If so then generally this is your culprit.
I have the car now for only two months and I do not know/have not the experience if the blower works correct.
As your car is 2003 then you may find that your Check Engine Light is caused by a leaking PCV system, see the other post floating around at the moment. You can get all sorts of codes from this.
PCV is what?
Okay, home again, no troubles, no messages..
Try taking out the fuse for the Wipers (refer to manual for correct one) this is generaly the fix for the headlight wipers when they point to the sky and stay there.
Fuse 5amps in glove box and 20amps in rear are okay. Wiper doesn´t work and rear washer pump also no noise and no water drop.
I didnt say "Check" the fuse - I said to remove it - this resets the Wiper ECU and may solve your problem.
For controlling the fuses I removed them, both, and put in new ones. First in clove box and then after insert the new front 5amps the same procedure in the rear with the 20amps......
Take the fuse for the wiper out, then turn the ign on, then off, then put the fuse back in and then ign on again and see if it resets.
