Home > Maintenance & Mods (L405) > Dynamic Response/ACE filter change
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Mine is due to have the filter changed, 65k 2017MY.
I understand that I need to replace the reservoir/expansion tank as the filter is built in. Do I need to change the fluid also?
My tech is worried it will need bleeding and apparently you need special tool to do so which he does not have. There is a manual way round this but unsure if it is even required.
Anyone know the procedure or what needs doing at this age/miles. Thanks[/code]
Post #683802 24th Jan 2024 7:27pm
fisha
You can syringe out the fluid from the reservoir tank, which will then let you undo the pipes to the tank to remove it without too much leaking. Replace the tank and refill, letting it sit for few mins so that any air in the pipes will rise back up to the tank to bleed. Run engine for couple of minutes. Let it sit again, and check the level again. That should be it.
The system can be thought of in 2 parts. One part having the reservoir, pump and valve block which generates the high pressure in the system, the second part having the valve block output and the anti-roll bar doodahs. The valve block controls the high pressure fluid generated by the pump and whether it goes through to the rollbars to control roll. At standstill, it shouldn’t be trying to control roll, so wont open the valves.
As long as you leave fluid in the pipes you disconnect the tank from, then after refilling and running the engine, just that first part of the system will re-circulate and purge air out of that first section, and on air should be passed through the valve block to the second part.
It’s the second part that supposedly needs bled in a particular way using a diagnostic tool if you get air in to it … but there are some on here who have worked on the second part and not needed any special tools.
I may have refilled the system once or twice …
https://www.fullfatrr.com/forum/topic65671.html V8 or else ...
Post #683828 24th Jan 2024 10:34pm
JamboM3
Very useful thanks!
Will order one up.
Post #683922 25th Jan 2024 10:42pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
The L322 has the separate ace filter, does the 2016 L405 have a filter integrated within the reservoir? The linked file shows a light shining through the tank, my reservoir has a baffle just below the oil level so the integrated filter comment does seem to be correct.
It is an important question to clarify as replacing the reservoir is around £150 whereas the separate oil filter is around £20.
Does anyone have the LR part number for the reservoir?
Post #684357 30th Jan 2024 8:02pm
Kot
Yes the whole tank and filter is 1 item when I got mine changed last year p/n was LR072550
204-06
The reservoir contains the main filter for the system which acts on the fluid
returning from the valve block; a coarse nylon-mesh filter removes
particulate matter from the fluid before it is drawn into the pump. The
filter/reservoir assembly must be changed at the intervals defined on the
vehicle service schedule and if a system hydraulic component is replaced.
 2018 SE SDV8 4.4 Byron Blue
Post #684361 30th Jan 2024 8:57pm
baz000000
JLR have confirmed that p/n and I've ordered a new (filter incorporated) reservoir along with 2l of STC50519.
Seeing the entire reservoir is changed I plan on pulling the outflow and return hoses and coupling the inlet to a pressurised oil filler to pump around the new fluid displacing the current oil in a catch bottle.
Post #684413 31st Jan 2024 12:17pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Pretty sure the L322 doesn't have a separate ACE filter, since it was never fitted with ACE. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #684417 31st Jan 2024 12:32pm
baz000000
It wasn't on my 2008 L322 but I assumed it was an optional extra since there is a tube video on the ACE setup in a 2006-2009 Range Rover Sport. They did say it was an optional fit.
Post #684462 31st Jan 2024 7:58pm
Danb_220_2019
Yes, it was fitted to the L320 Sport, but not to the L322 during its life. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #684507 1st Feb 2024 10:43am
